    How to Adjust Image Fields in Custom Print Report Templates
    By default, image fields in downloaded Custom Print Report templates are output using field parameters, so no additional template adjustments are usually required.
    However, if you have any of the following requirements, we recommend using the method below to adjust the image field template:
    1. The output image size is not as expected.
    2. You need to output image fields in Excel or PowerPoint format templates.
    Adjusting the Template
    4. After completing the setup, you can directly adjust the size and position of the inserted image to control the output size and layout.
    Note: This method only applies to single image fields. Multi-images upload fields are not supported.
    Output Blank Field
    After adjusting the template using this method, if the image field is empty and the downloaded file displays the field as shown in the image below, please edit the image field's "Alt Text" in the template by adding {field_parameter:ifEM:drop(img)}, then re upload the template.
    Signature and Barcode Fields
    If a Signature field or Barcode field does not display correctly, you can download the default template again. If re downloading the default template is inconvenient because you are using a customized template, you can also adjust the template using the method described above.
