Learning center
Full site search
    Automating Work with Ragic AI
    6 mins
    What Will You Learn?
    • Learn What Tasks Ragic AI Can Help With
    • Learn How to Add an AI Agent to Automate Tasks
    Key Concepts
    Ragic AI isn't just for building your database. It can also help you add records and automate your work, making your daily operations more efficient. Simply click the AI icon in the upper right corner of the page, or type @Ragic AI in a sheet, to call on AI assistance anytime. With Ragic AI, you can:
    Auto-Create a Record From an Uploaded File: Upload an Excel, PDF, or other file, and Ragic AI will read the content and populate the corresponding fields, quickly creating a new record.
    Using @ To Call AI for Automated Task Execution: Type @Ragic AI in a sheet to analyze data, edit or create records, export files, or send emails, boosting your overall efficiency.
    Adding Agents: Choose an AI Agent type and set your own rules, or apply a built-in template to get started quickly. For example, you can have the system automatically comment to notify the person in charge when "Remaining Budget" falls below 10% of the total budget, or schedule a weekly task to summarize sales orders and email the report to management. Once saved, Ragic AI will automatically execute tasks based on your rules, helping with routine work like checking records, filling in fields, and sending or replying to emails.
    With Ragic AI, you can hand off repetitive daily work to AI, saving time on manual work and boosting your productivity.
    Completed this course? Check the checkbox below!
