Follow us on Social Media!
Tips and Tricks
Case Studies
Data Drama
Talking Ragic
Product
Guide
About
Tips and Tricks
Case Studies
Data Drama
Talking Ragic
No Code
Automation
Digital Tips and Tools
Software Comparison
Templates
Use Cases
Government
Services
Retail
Manufacturing
Constructions
Energy and Utilities
Partner Story
Excel Catastrophe
ERP Nightmare
Paper Horror Story
Announcements
Learn Ragic
Ragic Story
By Nadya Tan
Table of Contents
Why Small Businesses Need Inventory Software
What to Look For in a Small Business Inventory Tool
Your Inventory System, Built with Just 3 Sheets
No-Code Inventory System
Step 1: Inventory Sheet
Step 2: Outbound and Inbound Sheet
Step 3: Automate Stock Count
Step 4: Track Stock Movement
Step 5: Low Stock Alerts
Advanced Inventory Features
2. Reduces manual data entry
7. Scales with your business
What is Ragic?
  • ● Set up fields like:
    1. 'Product ID': You can set this as an Auto Generated Field, with customized format as you want.
    2. 'Product Name'
    3. 'Category' (use Selection Field that will show up like a dropdown menu for faster input)
    4. 'Image'
    5. 'Current Quantity'
    6. 'Minimum Stock'
  • ● Save the design.
  • ● Build your Outbound sheet with fields like 'Outbound ID', 'Handled By', 'Outbound Quantity', etc. More fields can be seen below for reference:
  • ● You can set the 'Handled By' field with default value of #USERNAME so it will autofill with the logged in user currently handling this outbound entry.
  • ● Use the Link & Load feature to pull product info from your Inventory sheet, so whenever, for example, you are filling in the Outbound sheet, when you choose a 'Product ID', information like 'Product Name', 'Category', 'Image', etc will directly be entered.
  • This relationship between two sheets setup is as easy as connecting dots between two fields, no VBA, no complex scripting.
    Here’s how:
    • ● In your Outbound sheet, Go to Form Tools and choose Update value on another sheet action button.
    • ● Set the Inventory sheet as the target.
    • ● Select 'Outbound Quantity' as the value to deduct.
    • ● Set the operation to minus (-).
    • ● Select 'Current Quantity' in the Inventory sheet as the field to update.
    • ● Add a condition so that the stock is only deducted when 'Product ID' in the Outbound sheet matches 'Product ID' in the Inventory sheet.
    You’ll now see the 'Deduct Stock' button and a 'Reverse Deduct Stock' (You can rename the button if you want) button appear in the lower-right corner of your form.
    • ● Create a new outbound record.
    • ● Select the product and quantity.
    • ● Click Save.
    • ● Hit the 'Deduct Stock' button.
    Boom—stock updated.
    The 'Stock Deduction Time' field will auto-fill with the exact time you clicked the button, and if you check your Inventory sheet, you’ll see that the quantity has been adjusted accordingly.
    Here’s how:
    • ● Go to the Design Mode of Inventory sheet
    • ● Choose Form Tools > Show references from existing sheet.
    • ● Select the Outbound sheet and choose the fields you'd like to display—such as 'Outbound Date', 'Quantity', etc.
    • ● Insert the subtable, then Save and Exit Design Mode.
    • ● Add a new field—say, 'Below Min. Stock?'— and set the field type to Checkbox.
    • ● Then use this formula: IF(D3 > D2, 'Important', 'No')
    • This means: if the 'Minimum Stock' (D3) is greater than the 'Current Stock' (D2), it’ll return “Important”, which triggers the warning icon. Otherwise, it returns “No.”
    Scan barcodes, tap 'Add Stock' or 'Deduct Stock', and update things on the spot, right from your phone.
    Learn about Ragic Reports
    Inventory Management Template
