Will I be able to erase the current auto generated field so it starts at "1"?
Yes, you can reset or change the status of the automated sequence in the auto generate setting through the Sequence Status at the bottom. Enter the sequence number you want to start from and click the Set current seq button. If you would like to view the current sequence number, click on Get current seq.
For more information about auto generated fields, please see our documentation here.
Top of Page
    Start Ragic for Free
